OK, so as I continue to sort our new to us boat out, I have come to this situation:
2002 Tomcat with carbed Honda 90 HP Outboards. At extended idle times (something like over 3 mins., the port motor will start to stumble. If I go to squeeze the primer bulb, it is soft and after a few squeezes, it gets hard and the motor picks back up. The motors run fine at speed and do not falter.
I have replaced both primer bulbs with BRP units (correctly oriented regarding flow and upright attitude), tightened all hose clamps, checked all filters and associated lines.
It seems that I must be sucking air somewhere, but I'll be darned if I can find it or understand why this only happens at idle.
All suggestions greatly appreciated!
