- Joined
- Mar 3, 2005
- Messages
- 3,599
- Reaction score
- 2
- C Dory Year
- 2005
- C Dory Model
- 25 Cruiser
- Hull Identification Number
- TBD
- Vessel Name
- journey on
Pat,
To answer some of your questions. Dr Bob has covered a lot of ground, and I'll be short. BTW, it'll be easier and cheaper if you just replace the FLA batteries. Cheaper, but not as much fun.
1. The Suzuki alternator is internally regulated for FLA batteries. Cannot be changed to a Li cycle. This means that there has to be a lead acid battery connected to the Suzuki to prevent over voltage damage.
2. A DC-DC battery charger is a fancy name for a battery charger that connects in parallel with the FLA battery. When the engine is running, it can charge the Li battery. When the engine is not running, it will draw from the FLA battery (and house charger) to keep the battery charged.
3. The batteries you have selected have a BMS, which shuts off the charge and balances the cells. Both of these are good.
4. You need to keep a FLA battery in parallel with the DC-DC charger to take the alternator current when the DC_DC charger stops charging. Also, the Li battery will NOT start the Suzuki, not enough current.
5. You need your existing house battery charger to keep the FLA battery charged. Remember, the DC-DC charger will draw from the FLA battery when the engine isn't running, i. e. when you're on shore power.
6. You didn't ask, but most DC-DC chargers have a input to activate the charger when the engine is running and producing voltage. Install a manual switch so that you can charge when the motor isn't running. Also hook up a switch for the 1/2 rate charge.
