Larry Patrick
Dave Deem has a good system for filling both tanks on boat I purchased. You here a whistling noise when whistle stops you stop fueling. One tank is harder to hear. Anyway after day I picked it up and filled tanks. I had some gas dribbling down side of boat on hot day. This was okay since it was in driveway,but now that its in a slip I cant have this happen. Guess after filling up will try and burn a gallon from each tank. Dave said he had a pump you could use by removing fuel line,but I lost that post. Is this common to have gas weeping? Where would be good and easy to disconnect fuel line and what pump can you use if you find this leakage at slip. Will be needing to fill up again soon thanks.
