williamsburg
- Joined
- Oct 28, 2005
- Messages
- 32
- Reaction score
- 0
- C Dory Year
- 2006
- C Dory Model
- 22 Cruiser
- Hull Identification Number
- CDO22332I506
- Vessel Name
- DORYME
I and several other derelicts were wasting time, as usual, at our marina. A new 40 something Grand Banks had just pulled in and was searching for a mechanic to take care of numerous problems. The captain was in a state of misery and his wife was making things worse.
I noted that I had gotten rid of my 36’ downeast style trawler to reduce my time spent on problems and enjoy cruising. I had replaced this boat with a CD-22, Doryme. One of the morons I associate with stated that I had improved nothing. Every boat is trouble and my C-Dory still had an engine, fresh water system, AC & DC, bildge pumps, electronics, etc. I had reduced the problems somewhat but only slightly.
I know he is wrong, absolutely wrong. I decided that deadrise (whatever that is), LOA, horsepower, and all the other stuff you see in boat ads leave out the most important ingredient – what I will call PITA (pain in the a__) factor. The major difference between my current boat and the previous trawler was ‘pumps’. When I counted up I had twelve different pumps, excluding the engine and generator, each feeding at least one new problem area. I had an A/C water pump, bildge pumps X 4, shower sump, oil change, fuel transfer, fresh water, seawater washdown, holding tank, and a vacuflush vacuum pump.
The PITA factor would simply be the number of pumps times two – a PITA factor of 24 on my downeast trawler. I multiply by a factor of two because each pump feeds at least one other problem – i.e. the A/C pump led to two air conditioners and the fuel transfer pump moved diesel between five tanks with a bunch of tubes and valves.
This may possibly improved on but it is simple and direct. Length is not a good indicator. I was recently on a Camano 30+ that was as Spartan as my C-Dory. Enumerating accessories is cumbersome and may be misleading. How do you compare a radio with a macerating head.
I hope this catches on and becomes a useful factor to the boat buyer.
