redbaronace
- Joined
- Aug 29, 2012
- Messages
- 582
- Reaction score
- 0
- C Dory Year
- 2007
- C Dory Model
- 255 Tomcat
- Hull Identification Number
- CD025558G607
- Vessel Name
- Tomcat
Came to the marina today and found my batteries drained very low. Its been 9 days since we used the boat and did not hook up to shore power when we left. I know that the fridge does use some battery, but we never had an issue before with the batteries being run low or the pump staying on.
After plugging into shore power, the batteries began to charge, but I noticed a sound coming from the transom. It appears that the port side bilge pump is running constantly. I checked the switches at the helm and the port pump light switch is lit up even though it is in the off position. It always stayed lit before as well, so I'm not sure if this is related or not.
There was a small amount of water in the bilge and it slowly all got removed until it was just a trickle coming from the bilge. Because I was worried about the pump running while dry and burning out, I placed a running hose in there. The pump is still running but at least it is pumping water through it while I figure this out.
Any suggestions as to what I should do or might try? I do not think I can get my electrical guy here to troubleshoot tonight.
Bummed.
Bummed.
