mikeporterinmd":1f4j0dn3 said:We just kind of plopped it up there to see if it would fit. Have to be careful
not to mash the compass. How are others securing the unit? If I install
the L bracket that came with it across the top, is that likely to be enough?
Worked well. Cooled the cabin off in just a few minutes and dried out
the air nicely. There are more photos in my album.
The digital temperature setting is worth it. The remote control...well...
Mike
flagold":1gws5jc8 said:I'm finally a cool dude.
CHardy":1vmpwcke said:Mike,
what did you do to the front window brace/holder that normally keeps the window open when tightened. On mine, it is attached high on the port side of the window frame and looks like it would be in the way. If I remove it, I won't be able to keep the window open when I want to.
Chris
CHardy":3chg6iw3 said:Mike,
have you thought about using winter water pipe protection sponge to slip on each window frame. Might be easy to put on and take off and still protect the metal.
also, I think the condensation will drain outside since it seems to tilt backward with placed in the window.
I will try to install mine this week and share if I come up with anything useful.
Chris
Bob – you are a tougher man than I am when it comes to hot weather. I would not call 80 to 90 degrees a comfortable temperature for working in. It would have to be another 20 degrees cooler for me.thataway":14o3hkro said:But I am amazed that the 5,000 BTU cheapie can bring the temp down to a level wlhere it is comfortable to work!
