PROBLEM ON THE HORIZON - ETHANOL???
I've never read the regulations, just derived what I figured were the rules from two comments on page 273 of the WM catalogue:
"Clear plastic see-thru bowl is for outboard installations only"
and
"See-thru bowls allow easy visual inspection for water; metal bowls are recommended for use in areas of high heat and are required by the U..S. Coast Guard on gas inboards."
Plus reading betweeen the lines, looking at all the products, and thinkin' about it.
Joe.
I suspect you are right Joe. Ain't never been wrong, I bet!! :wink:
Seriously, it makes sense to have a clear bowl and drain method if it is in the open -- just can't seem to find the CFR to authorize it. Old and slow... :wink:
Larry:
My regs are older than dirt - Googled it.
Fun rendezvous, huh?
Dusty
Larry H / Nancy H:
I don't think your posting was deficient in any way - it highlighted an important point for all of us - THANK YOU. Glad to see we might have communally got to the bottom of this!
