To answer the "backwards turning" prop question , We have found with planing type catamarans that there is a slight gain in speed [probably related to "bite" in cleaner water,or lack of slip] and no steering downside as you would have with closely spaced props on a monohull . Not exactly sure why , but we have done it this way for years on our Tomcats and Twin Vees and Sea Cats , and it works ! Dont know if it would make a difference on a pure displacement Cat like a G.B.
5700 is quite acceptable [ for a 4 stroke Yamaha] RPM with a load in the boat . The pitch Vs. Diameter you have is good . What you can gain by changing blade shapes is the ability to trim the bow higher . That is important on Cats . I usually suggest folks to trim up [ at speed] till the motors cavitate , and then back it down till they bite again and note those positions if you have trim gauges or "time it" if you dont . You need to drive by feel . Dont be afraid of the trim buttons ,they are your friend.............
Marc
Marc
