The idea of an ENCLOSED head was a huge selling point for Meredith. She could've/would've done the porta-potty, but she gently reminded me of our gran-
DAUGHTER.
That said, the thought of carrying a tank of...well, you know what, up the dock, up the ramp, up the stairs....no thanks and transporting it home? NOPE. We both see enough crap at work. Literally.
(Her more frequently) The pump out feature works fine for us. We finally used it enough to required the first pump out; pull up to dock, remove cover, pull hose over, switch on...pretty painless IMO. I even carry a box of Nitrile gloves on board to make "clean up" easier. We plan to use any on-shore facilities when available, but the tank is a no brainer.
Now on to the true story of the leaking pump out hose connection. Yep...you guessed it. :x After the first pump out the boat was in the driveway a few days, in 80F temps. Upon my first entrance into said boat I was welcomed with the smell of raw sewage. :shock: :amgry Upon opening the galley cabinet it "intensified". :amgry :amgry Seems a joint at the valve was leaking. The hose clamps were not securely tightened and a trail of "brown" had run down the interior of the hull and deposited a "puddle" right where the hull and side of the hull met. Fortunately, it was a minimal amount and the swale in the hull design acted as a nice dam/container, restricting said puddle along the hull, front to back. It
did not flow under the front cabinet OR the rear shower/head, thankfully. Cuss a lot, don a pair of Nitrile gloves and a half hour of clean up with a Clorox and water solution and numerous paper towels made the air more breathable. I then tightened down ALL the hose clamps I could see. So anyone with a new boat may want to take a look see at those clamps.
