kennharriet
Member
- Joined
- Jan 22, 2009
- Messages
- 543
- Reaction score
- 2
- C Dory Year
- 1999
- C Dory Model
- 22 Cruiser
- Vessel Name
- Lochsa
Sorry I don't have pics but will try to better describe what I did to ensure centering when loading the boat. I bolted 2"x6"x8"Trex board vertically on the trailer cross member channel, aft of the axle, on each side of the trailer against the frame channel. I cut the Trex material to match the angle of the hull side. I lined the edge of the Trex with indoor/ outdoor carpet, attached with 5200. This was to prevent chaffing where contact is made with the hull. Each piece of Trex was mounted with two stainless bolts. What this set up does is capture the hull as the trailer raises to meet the hull. The boat is centered by the time the hull makes contact with the bunk boards and stays that way when traveling. There is about 1/4" play on each side so it is not. Tight fit causing chaffing. Hope this helps. Will try to send pics when home next. Ken
