Active member
- Joined
- Feb 23, 2012
- Messages
- 3,990
- Reaction score
- 13
- C Dory Year
- 2002
- C Dory Model
- 22 Cruiser
Hi folks,
I have a question about something that just happened and I don't know if it's a big problem or not.
When I fuel, I always have a small piece of "fuel diaper" that I set next to the filler opening - just in case, and to wipe off the nozzle before taking it out, or etc. Well, the last batch of fuel diapers I bought have a different "texture" than the ones I've had before, and I found that they tend to shed bits of fluff. I have been very careful, but today, just as I had finished fueling and was moving the nozzle out of the filler, I'm about 80% sure a small piece of fuel diaper "fluff" went down into the filler :amgry I did get one small piece out, but I think another may have stayed in there. I fished around in the filler hose with a piece of seizing wire I had made a "hook" on the end of (in case it had stuck to the bend in the filler hose and not gone all the way down), but no luck getting anything out. Naturally it had to be the starboard side tank with the lesser bend in the hose.
Anyway, here is my question: Presuming a piece of "fluff" DID get into my tank, will it end up causing a problem? I don't think it's large enough to block a screen on the end of the pickup tube (if there is one... I kind of hope not as I don't really like them there but I don't know for sure how Moeller does them), but if it did get into the fuel lines, would the external Racor filter pick it up and then it would be gone after I change the filter (which I will do after this trip)? Or is it something where I should take my fuel system apart until I find it (if it is indeed there). I hope not, of course, but don't want to worry about something "looming" either. The rest of "those" fuel diapers are going in the garbage! (Most that I've had are not like that at all and don't "shed.")
If it were you, would you keep on running on this tank? (I had purposely used up all the fuel in the other tank preparatory to getting off the lake, at which time I put in stabilized non-ethanol fuel for storage time.) I really don't know if it's
a)A crisis and I should stop right now and not run.
b)Nothing to worry about (but of course change Racor after this trip).
c)Somewhat independent of above, if it does not show up in (on?) the Racor, should I be tearing the fuel system apart until I find it?
If the piece did go down in there, it's about the size of a small grain of rice, although "fluff shaped," not rice shaped.
