Active member
- Joined
- Feb 23, 2012
- Messages
- 3,990
- Reaction score
- 0
- C Dory Year
- 2002
- C Dory Model
- 22 Cruiser
Just a note: I think the Honda 115 is kind of a special case, in regards to weight/horsepower. It's really their larger engine, "de-tuned" to run at lower horsepower. So it's quite heavy compared to other 115 hp engines. Thing is, the stern of a C-Dory 22 was designed around the day's 250# 70 hp 2-stroke and a pair of 18 gallon gas tanks. Now we have 90+ hp four-strokes (heavier) and larger gas tanks, more batteries, etc. In other words, it's "skinny" for modern day engines (compare to the Cape Cruiser 23 or Marinaut 21, which are evolutions of the design, and have more buoyancy aft, which better supports modern-day heavier outboards, more fuel aft, etc.).
This is not to say the 22 is a bad design, or cannot manage many 115 hp engines (or even possibly the Honda 115). But probably keeping it lighter in the stern is better, if it can be comfortably managed (and it can, as the many 90 and lighter 115 hp engines seem to work fine).
Just to give you a comparative idea:
The Honda 115 weighs 478# and is ~2350cc.
The Yamaha 115 weighs 401# and ~1750cc.
The Suzuki 115 weighs 401# and is ~2000cc.
The Honda 90 weighs 360# and is ~1500cc.
The Yamaha 90 weighs 366# and is ~1600cc.
The Suzuki 90 weighs 341# and is 1502cc.
The Honda 40/50 weigh 415# each.
The Evinrude E-Tec (2-stroke) 90hp is even lighter than the four-stroke 90's (although their 40hp is "heavy," so it's not always true that the E-Tecs are lighter).
Alternators also vary, so another thing to check.
Anyway, from this you can see how the Honda 115 is a bit of an outlier. Paired with the typical kicker it would be a pretty heavy combination on the transom. Granted, today's engines are so reliable that (depending on preference and boating habits) you could go without a kicker. But by that logic you could also go with one of the other (lighter) main engines and no kicker and be lighter yet (can you tell I've tried to justify the Honda 115 for my own 22?
I've been out on a boat with the Honda 115 for an afternoon (actually a pair of them on a Rosborough), and I thought it was a fantastic engine. But not sure I would put one on the 22, myself.
