seahooked
- Joined
- Mar 18, 2006
- Messages
- 166
- Reaction score
- 9
Seahooked is making the move from dry storage to covered wet moorage at Edmonds marina later this month. Bottom paint is scheduled for next week, along with zincs on the trim tabs. Some questions since this is new territory for me:
- What cleaner can you use in the cockpit and on the exposed hull without sudsing up or polluting the water? Something that can kill mildew.
- I've always used the solid pellet dehumidifiers to keep the cabin dry. Since I now have power available should I switch to a small heater? If so, use a separate extension cord instead of the shore power cord because of possible issues with galvanic corrosion?
- How long do the zincs typically last when the boat is always in the water?
- I like to do my own engine maintenance but I'm the thought of changing oil and gear oil on the water scares me. I've read some prior posts about how this can be done successfully but I'm still nervous. The alternative is an expensive haul out fee (I have no trailer). Has anyone else faced this scenario?
- In Puget Sound does everyone leave their engine down in the winter to keep trapped water from freezing?
- Any other tips are appreciated as well.
