freedomvango
- Joined
- Dec 12, 2024
- Messages
- 23
- Reaction score
- 0
I anticipate this will be a lengthy post with lots of numbers. I’ll document the process as I go, so you can decide if this is something you'd like to take on as well.
Problem:
2022 R23 with AGM batteries, air conditioning and heat that only work on shore power, and a single solar panel.
Solution:
Upgrade the entire power system to support faster shore power charging, lithium charging from the outboard, a larger solar array, and reconfigure the breaker panel to support a larger inverter/charger.
Parts List (abridged):
3 x 320 AH Dakota lithium batteries (current model in use)
1,200W solar array on a custom rack extending over the bimini
Orion DC-to-DC charger for charging from the outboard
2 x Victron 100/50 solar controllers
Multiplus 12/3000 inverter/charger
Cerbo GX and Touch 70 for monitoring
SmartShunt IP67
IP22 charger for starting and thruster
Class T fuse and holder
Various bus bars, wiring, and related components
Plan:
The goal is to place the batteries and related components where the factory batteries are located, in the port-side locker. This configuration should work for both the R23 and R25 models.
I will remove the existing charger, the ACR for the house batteries, and any other unnecessary components, replacing them with the upgraded system listed above.
The inverter installation will be a bit challenging, but I believe I can fit it in the space where the factory inverter is located. I’ll need to build a bezel to extend the panel slightly into the berth area to make room for the inverter, but overall, it’s a manageable task. Additionally, I’ll likely remake the fascia panel on the CNC to reposition the battery switches under the AC panel, rather than beside it, and rearrange components to optimize the layout.
All the parts are currently at the shop, except for the batteries, which are expected to arrive by the end of the year.
While we are traditionally van builders, I love the Ranger Tug because it’s essentially a van on a boat—perfectly aligned with my needs. I’m excited to begin working on our R23!
Problem:
Solution:
SmartShunt IP67
Plan:
