- Joined
- Mar 3, 2005
- Messages
- 3,599
- Reaction score
- 2
- C Dory Year
- 2005
- C Dory Model
- 25 Cruiser
- Hull Identification Number
- TBD
- Vessel Name
- journey on
Journey On has a RACOR fuel filter between the gas tank and the engine. As far as I know, every C-Dory that has a built in gas tank (C-25, TomCat, Venture,) has at least one of these.
To go into more detail, the RACOR element P/N is S3240. It screws into the fuel head, and then a sediment bowl screws into the bottom of the element. Works well, at least until I try to change them.
This year, the element came off the head, but I couldn't get the bowl off the element. Cut the filter open (try that with a gasoline filter,) and the black plastic ring was stuck in the transparent bowl. Broke the ring, still wouldn't come out.
So, has anybody else had that problem?
Called RACOR, in Modesto, Ca. Phone No. 800-344-3286, on the new filter. Yep, that happens, and their engineers are working on a fix. That's been for over a year. Well, they said they'd send me a new bowl and filter, which is SOP.
Just thought I'd mention it to see if there's another solution.
