Hunkydory
Active member
- Joined
- Mar 28, 2005
- Messages
- 2,751
- Reaction score
- 22
- C Dory Year
- 2000
- C Dory Model
- 22 Cruiser
- Hull Identification Number
- DOR22916I000
- Vessel Name
- Hunkydory
Would appreciate opinions on what would be the an adequate radar reflector for a 22 CD. Would like to attach it to the anchor lite mount. BEST REFLECTOR FOR LEAST COST.
Also our JRC 1500 Radar SHM [ships heading marker] on the monitor is always off 40 degrees to starboard. I have did the Relative Bearing Alignment procedure and that just creates the ELB [electronic bearing line] as a substitute for the SHM still off 40 degrees to starboard. In other words a object that I'm heading directly for shows on the radar monitor as 40 degrees off to the starboard and when I try to align it all I get is the EBL off the same amount marking the object. I have tried physically moving the radar scanner unit with no success either.
If I set up a route or waypoint and have it as a go to on the radar screen with the gps signal then the SHM is accurate. I can get by this way because most of the time when radar is needed I would be following a route or at least going to a waypoint but would like to know if I'am doing something wrong [most probable] or if something is actually wrong with the radar.
I first noticed this last fall on Yellowstone Lake when I was practicing with the radar on a on coming boat and the boat wasn't where it should have been on the radar. Could have been a bad deal if we had actually been in the fog.
