drjohn71a
- Joined
- Jul 15, 2004
- Messages
- 1,820
- Reaction score
- 0
- C Dory Year
- 2007
- C Dory Model
- 255 Tomcat
- Vessel Name
- Tom-a-Hawk
Sailed Away.... Lots of questions there....
Well, as for running a cabin heater off the hot water from an engine, that would require some type of inboard engine with a closed cooling system and a "radiator" bathed in seawater coming from holes in the hull. The Ranger 25 has an inboard diesel whose coolant stream can be piped up to a cabin heater. You'd have to be running the engine all the time for the heater to operate all the time.
The R25, CD25, and TC255 all have Wallas diesel stove/heater options. The Wallas can sometimes be finicky, but most of the time, it provides great, reliable, cheap, relatively quiet, low amp draw heat. i.e., you can use it at anchor with few problems if your house batteries are OK, but best to start it when the engines are on to get the most robust starter action.
The R25 and the TC255 are near the same weight, I think... others may know more about that here. Although quite impressive high on it's trailer, the TomCat tows very easily with great stability and control using a 3/4 ton truck of any of the major brands. The CD25 is a bit lighter, and sits lower on the trailer than the other two. It is easy to tow also, as is the Ranger 25 per some owners. All three could use a 3/4 ton pickup though.
When it comes to running at higher speeds, teens and above, in a chop, the CD25 is reported to pound less than it's smaller cousin, the CD22. The CD25 runs best with a 150 hp outboard, the TomCat (a power catamaran with two hulls) runs best with two 150 hp outboards.
The cabins of the CD25 and the TomCat are similar in layout and size except that the TomCat's cabin floor is even with the cockpit floor, the TomCat's front bunk is gigantic, and there is much more under the floor storage in a TomCat. The TomCat's aft cockpit is much larger than the R25 or CD25 due in large part to the Armstrong brackets, swim step, outboard mounts.
The sea action is more like a displacement sailboat in an R25, a bit less in a CD25, and the TomCat is rock solid stable like a catamaran sailboat. The TomCat's forte is traveling 22-33 knots in 2-4 foot seas - it runs smoother at those speeds in rough water than at slower speeds.
All three boats can be operated economically at hull speeds... 5-8 mph or so.
Diesel fuel is hard to get in most inland and MidWestern state lakes, but diesel engines require less maintenance than gas engines in general, but the Honda engines have lasted as long as diesels in many applications.
Winterwise - I've had inboard engines in many of my boats. Messing with the bilge is a constant headache whether diesel or gas. You can get air cooled generators to run with the outboard engines, so no conflict in that area. When freezing hits, if you use your boat in the winter, you just tip the outboards up, maybe spray the plug hole, and that is it... no running antifreeze all through all the accessories needed. If you're in the water, just tip the engine up and you're done.
However, even if you're in the water, you cannot leave an inboard engine without some kind of heat going to all the engine coolant and exhaust coolant areas, or it will freeze and damage the engine. Same problem if you take the boat out of the water and plan on trailering it in freezing weather. You would have to install antifreeze pretty close to the ramp to stop freezing damage.
Also, if a major engine problem, swapping an outboard is not much problem...
Two engines... today's engines are extremely reliable, but sometimes, when a storm picks up, the trash/water in the fuel will jump up and get into an engine at the worst possible time. How nice to have TWO engines and TWO fuel tanks, and TWO fuel filters!!!!!
Two engines on a TomCat are very widely spaced and you can actually steer the TomCat with the engines straight, by placing one of the other in gear. You can spin the TomCat on a quarter... not quite a dime... very easily. The handling is extremely easily controlled.
The TomCat gives the helmsman a feeling of ultimate control - like running on railroad tracks... very addictive! The CD 25 is lighter and a bit more economical, pretty close. The R25 is so beautiful!!!, but can't go very fast... and you've got to manage that bilge continuosly.... AARRRGGHHH... I hope to be done forever with bilge management... I like 'em all, but love the TomCat.
