Active member
- Joined
- Feb 23, 2012
- Messages
- 3,990
- Reaction score
- 16
- C Dory Year
- 2002
- C Dory Model
- 22 Cruiser
I'm installing my new Raymarine A98 chartplotter, and in addition to the main negative wire, it has a "drain" wire. This wire is one of those tiny, hair-like wires. They say to connect it to the RF ground if your boat has one (of course ours do not) or to the negative battery post. Specifically, here is what the Raymarine forum guru posts when folks ask:
Should the vessel be equipped with outboard engine(s) and not be equipped with a bonding cable, then the drain lead should be connected the battery's negative post.
Okay, so that's us. But connected to the battery's negative post?
1) I don't connect things to the battery posts directly unless I absolutely have to, and plus I especially don't on the negative post because the cable from that goes directly to the shunt for the battery monitor *before* any loads (cable goes from shunt to negative bus, where loads attach).
2) Does that really mean anything that GOES to the battery's negative post? Like the negative terminal on the negative bus that C-Dory put in the V-berth "behind" the helm where I already connected the main negative wire from the plotter? I could cut off that ring terminal and do it again but shove the hair-like "drain" wire in there with it before I crimp it, if that would be appropriate. (Otherwise, how the heck do you connect these tiny things?)
Would like to get this up and running, since I'm at Powell and took out my Garmin 2006
OTOH, I don't want to mess anything up.
