Well-known member
- Joined
- Oct 2, 2011
- Messages
- 5,103
- Reaction score
- 71
- C Dory Year
- 2009
- C Dory Model
- 25 Cruiser
- Hull Identification Number
- UWH25301J809
- Vessel Name
- C-Traveler
"With the autopilot struggling to keep a heading at 3 mph while trolling, do you believe that a larger pump motor would have helped?"
No. The pump was having no problem moving the outboard. That being said, would a larger pump turn the outboard any faster? Perhaps. However, I don't remember the a/p actually turning the outboard full throw, although it is capable of doing that.
"Have you swung the compass? How much off, is the EV-I sensor from your GPS magnetic heading? Were the courses you were taking, such that there was a significant deviation from the GPS calculated course?"
GPS magnetic heading and EV-1 sensor are within 2 degrees of each other. The compass does not really come into play, other than to be a manual backup. It's close enough for C-dory work!
My course was actually a straight line route, that was previously set up in my GPS. AP was having a hard time staying on that course, so I simply disconnected the AP from the GPS, and used it in the manual mode of following a heading only. This allowed the AP to work a bit better, but it would still end up turning off heading from the quartering seas at the slow speed. I suspect this was from slow reaction by the autopilot, and it failing to correct in a timely fashion. Also, it's almost like it just gave up and alerted that it was off course. (Us humans preempt that bow swing immediately when it starts to happen.) If I wasn't worried about tangled lines, I would have let it gone to see how long it would take to finally correct itself. (I did reset the autopilot to a more sensitive tracking mode, but that did not help.)
"Three MPH is a speed where an auto pilot should work OK--it is down in the 1.5 or so MPH that they begin to really struggle more. The EV-i heading sensor is a 9 axis sensor, so it should handle the slow speed, and the difficult circumstances of quartering seas."
One would think so, but it does not. My trolling speed was between 2-3 mph. Even on very calm water, at no-wake speeds, the EV-100 seems to have a hard time staying on course. Speeds above that, then it seems to do ok.
Colby
Colby
