Well-known member
- Joined
- Oct 2, 2011
- Messages
- 5,064
- Reaction score
- 29
- C Dory Year
- 2009
- C Dory Model
- 25 Cruiser
- Hull Identification Number
- UWH25301J809
- Vessel Name
- C-Traveler
Finally! It works! Got the new helm and installed it today. Also resealed the outboard hydraulic steering cylinder. So in the end, it was the cockpit helm that was the culprit. Most likely a bad check valve or shuttle valve. In any case, two brand new helms (one in the cabin, one in the cockpit), the resealed cylinder, and some hose work, I should be good for quite some time. The hose work involved removing the tees at the cabin helm where the cockpit helm tied in, and at the cockpit helm where the a/p smart pump teed in. Instead, I teed in to the main hose (between the cabin helm and the cylinder), under the galley countertop where my autopilot smart pump is installed. I ran a small branch hose off the mains, then hooked both the smart pump and cockpit helm into that. No leaks that I could see anywhere, and the boat steered as it should when I took it out for a quick test spin. I still have about an inch play in the cylinder if I push the outboard from side to side, but I suspect that is normal. Either that or some air hidden in the system somewhere. But I bled it today until there were no more air bubbles anywhere.
