Well-known member
- Joined
- Oct 2, 2011
- Messages
- 5,079
- Reaction score
- 34
- C Dory Year
- 2009
- C Dory Model
- 25 Cruiser
- Hull Identification Number
- UWH25301J809
- Vessel Name
- C-Traveler
Harvey, I talked to my brother, an Electronic whiz, (electronic technician by trade) about this first, as I was worried about to much current and all. He said if I'm going from almost 14 some volts from the car altenator, to a battery with 12 volts, that is only a 2 volt difference and the amperage draw would be very little. The fact I have not blown my 5A fuse shows I'm transferring less than 5 Amps thru my system. I have used both C-pap and my Webasto heater at night on the road, but never seen the battery below about 11.9 in the morning, (usually with a load on it, and as indicated on one of my chartplotters voltage readout.) More normal is about 12.1 volts with no load. I also have a 10 amp fuse on my accessory (cigarette) outlet at the helm. After driving all day, my boat house battery is back to about 13.2 volts. (Probably back up sooner, but I don't check it until done driving in the evening. ) I fabricated my system for about $10. The cost of the plugs at both ends of the wire, that I already had!
BTW, FWIW, I've left the system hooked up, and ran the heater with no ill effect. I don't know what kind of current the glo plug pulls, but I'm sure it's more than 5 amps. However, I also think the boat battery is providing the current necessary, so still little draw on the "tow" system. I believe I remember my brother saying that the length and size of wiring would also act somewhat limiting on the amount of current traveling thru. I'm just a layman at this, so don't remember everything he explained to me. I just know it's working for me. Colby
