Active member
- Joined
- Feb 23, 2012
- Messages
- 3,990
- Reaction score
- 13
- C Dory Year
- 2002
- C Dory Model
- 22 Cruiser
Mark,
Thanks again for the explanation. It makes sense. Yes, it was the fuel tank manufacturer's instructions which said to ground the fillers. Now I understand that that "works" when the boat is in the water, but not when it isn't.
As for grounding the motor leg, I was just thinking of a wire with a clip on one end and bare wire on the other end. I already have to do a bunch of routine things when filling at a gas station (get out fuel diaper, gloves, fuel treatment, log book, close cabin door, etc.) so I don't think it would be a big deal for me to add one more. It might be easier than touching the nozzle to the fuel filler cap and then finding a place to set the nozzle down (and then trying to reach it from in the cockpit - which is much more of a height difference on land). I have the traditional fillers that open with a key, which I like.
But just so I know my options, I now get that I could touch the nozzle to the closed filler, then put it down and open the fills, then fill. But let's say I wanted to do it the strap way (on land). Would that just be a length of wire that I could clip onto the engine (obviously on a bare place, maybe the end of one of the engine attachment bolts?) and then let touch the ground during the fill process? I think that would be easier for me, as I could do it in controlled fashion before/after I'm dealing with the pump nozzle. I would add it to my checklist/routine when filling on land. Would be small to carry.
