- Joined
- Mar 3, 2005
- Messages
- 3,599
- Reaction score
- 2
- C Dory Year
- 2005
- C Dory Model
- 25 Cruiser
- Hull Identification Number
- TBD
- Vessel Name
- journey on
That sealant is Bostic . The factory used it on ALL joints, and it not only doesn't help, it prevents the nylon hose from seating on the barbs. They used it to seal the hull, seal the plumbing and seal bolts. They must have bought it by the truckload.
To loosen it, just turn the hose on the fitting with a pair of plires. If it sticks, try a little heat. Don't forget to remove the goop from the fitting.
On Journey On's hot water heater, there are 4 ea. plumbing fittings as follows:
Top right-overpressure valve
Top left-hot water outlet
Bottom right- cold water inlet
Bottom left-drain valve
There are 2 fittings at the rear and these are for an engine heat exchanger. Unfortunately useless on an outboard.
I'm not sure what a RV bypass kit is, but if you still want (cold) water to the hot water faucet, I'd just trim the outlet and inlet hoses and join them with a hose barb and clamps. Don't forget to plug the overflow and drain hoses because they lead to the shower sump pump, which if it backs up can cause those hoses to overflow. Also check to see that the inner lining isn't separating on the nylon braided hose. Never seen it except on Journey On, but there it was.
