jackpepper
- Joined
- Sep 30, 2019
- Messages
- 4
- Reaction score
- 1
How do you reattach the rubrail at the bow of my 22 cdory. about five of the rivits have pooped out.What is the best way to reattach the rail
I had a similar issue when trying to drill out my rivets. One option is having a helper inside holding the rivet with pliers, another is to use a dremel with a conical bit sized to fit the rivet. The high speed of the demel is usually fast enough to prevent the rivet from matching it and a diamond cone has much less "bite" than a drill bit. Finally using a small punch to tap the body from the outside in can help also.i've never been able to get the old rivet bodies out. I've tried to drill them but they just spin around. I replace them with lag bolts. It work
on my tomcat the rivet backs aren't accessible. I figure those lag bolts will hold forever, especially considering i butter them up with 5200. I don't know why builders insist on rivets that only last a bit over a decade.I had a similar issue when trying to drill out my rivets. One option is having a helper inside holding the rivet with pliers, another is to use a dremel with a conical bit sized to fit the rivet. The high speed of the demel is usually fast enough to prevent the rivet from matching it and a diamond cone has much less "bite" than a drill bit. Finally using a small punch to tap the body from the outside in can help also.
