Well-known member
- Joined
- Nov 2, 2003
- Messages
- 21,822
- Reaction score
- 160
- C Dory Year
- 2007
- C Dory Model
- 25 Cruiser
- Hull Identification Number
- DOR25652A707
- Vessel Name
- thataway
alacrity, I don't plan on removing the wooden interior. I wonder why you could not clean them in place (my 22 had the "wooden laminate"--and I used various cleaning materials to spruce it up.) However, it is easy to cut the tab, right at the bend, grind it down, and then re tab it. These tabs are only where the "L" brackets are located--and not a full tabbing in a structural bulkhead. (I have removed full structureal bulkheads when rebuilding a boat--and that is not much more difficult--you use a right angle grinder and cutting wheel, to cut the glass at the angle--grind it down, and re tab.
The tabs are about 2" square and precut. I in the one I photgraphed, I had drilled out the screw hole and filled it with Marine Tex, filled the holes in the laminate, then used epoxy to set the tab--it is a fairly quick fix--actually faster than re installing the "L" bracket.
As far as duvalra, I think he just posted himself off the list by insulting Boris. The irony is that he mistook the function of the pop rivets and doesn't understand how the boats are constructed--at least in the boats I own, the hull to deck joint is fiberglassed together. This is the best and strongest way to build the hull to deck joint. The pop rivets are just for the rub rail extrusion, and are epoxied or have some other putty type of filler on the inside. I see many very bad hull to deck joints--C Dory does not have bad hull to deck joints.
