Swee Pea
- Joined
- Nov 2, 2003
- Messages
- 412
- Reaction score
- 2
- C Dory Year
- 2004
- C Dory Model
- 22 Cruiser
- Vessel Name
- Swee Pea
I have a camper that has a hand held shower. It is a small enclosure with a cassette toilet. It has a built in shower pan/drain, but the walls are luan covered with vinyl (I think) and not waterproof. There is a shower curtain that goes around which further reduces the shower area. I wish that the enclosure was made of plastic or fiberglass, but there are odd angles and molding one would be expensive.
I found this product www.neken.co.uk which are plastic 12"x12" wall tiles, that when applied properly, will create a shower surround. Exactly what I want. The roblem is that there is no distributor in the U.S. and cost becomes outrageous with shipping and VAT tax. I guess I could use a high grade of sheet vinyl flooring and glue it to the wall. But this Neken system is perfect. I have looked all over the Internet for vinyl coatings to be glued up, but all are developed for overseas use and are located in Europe.
My question is - is it possible to use a clear resin to coat what I already have and create a watertight surface for the occassional showers that I will be taking in the camper? Something that will not crack and can be applied by brush or roller? Something that can be easily cleaned and not wear off. I don't want to use fiberglass cloth and such. It also needs to be able to flex some, because it is in a camper and also light weight.
I don't know much about resins and such coatings, so I need the Reader's Digest version of possibilities.
I know that many of you Brats can lead me in the right direction OR head me off at the pass.
Thanks in advance.
Swee Pea
Thanks in advance.
Swee Pea
