Hello,
I was working on my 16 ft. C-Dory in the evening, the lighting I had wasn't great, and I managed to hook the positive voltage lines to my engine to the negative terminal and the negative voltage lines of my engine to the positive terminal. Needless to say, I saw the spark on the battery terminal as the short happened, heard a pop under the engine cover on the 1985 50HP 2_Stroke Johnson, and smelled some smoke waft out from under the engine cover. I didn't see exactly what component in the engine failed at the time. I later checked all fuses in the engine, none were blown. I noticed that the bottom of the fuel solenoid (http://www.go2marine.com/product.do?no=153667F) looks like it has small bubbles in the plastic (burnt?), so maybe this is the part that failed (or maybe the bubbles were in there at time of manufacture).
When I try to start the engine now, it cranks, but won't start.
If anyone else has any guesses as to what part(s) may have gone bad, I'd really appreciate it.
Thank you,
-Max
max@tealeaf.com
Thank you,
-Max
max@tealeaf.com
