Active member
- Joined
- Mar 1, 2005
- Messages
- 7,515
- Reaction score
- 24
- C Dory Year
- 2007
- C Dory Model
- 25 Cruiser
- Hull Identification Number
- TBA
- Vessel Name
- "Wild Blue" (sold 9/14)
bjidzik":1uez9x5c said:We moved up from a 16' to a 25' Cruiser in October. What a difference in handling! We only have around 20 hours on the new boat so far.
Compared to the 16' & the 22' Cruisers we rode in, the 25' is much more comfortable in light wind & chop. I've also found the 25' is a bit easier to maneuver in the harbor.
What I'm still trying to figure out is the best tilt & trim settings to improve fuel economy. We have trim tabs, but no permatrim. I've contacted several folks about the best tilt & trim adjustments on the 25' cruiser for handling. General consensus was to tilt the motor all the way down to push the bow down and use trim tabs to adjust to plane. Anyone have other preferences?
Thanks![]()
It was eye-opening for us to put a fuel flow meter on Wild Blue. Using that, we are able to trim for the best fuel burn for a given speed/rpm. What has worked for us regarding trim: I generally adjust the tilt so that the prop is staying perpendicular to the water surface and adjust the trim tabs to give us the most comfortable ride. It's a "moving target"... when the water is flat (rare), I seem to get the best mileage with a bow up (slightly) trim. When the chop builds up, we will trim the bow down for a more comfortable ride. Then it's a matter of adjusting the rpm to get what I feel is the best balance of speed/comfort/fuel burn. Depending on conditions, we may get better fuel efficiency at 18 knots compared to 15. That range between 9 and 12 or 13 is generally our least efficient fuel burn, until we get around 20 knots.
The fuel flow meter really helps when running at speeds less than 9. Again depending on conditions, we generally see about 5-6 knots at 1800 RPM, burning just under 1 gallon per hour. Bump that up to 2000 RPM and our speed might go up a couple tenths of a knot, but the fuel burn goes to 1.4 gallons per hour. Doesn't sound like much difference until you look at it as a ratio: to gain less than 5% more speed, you are burning 40% more fuel.
When just bopping around or cruising in places like the Erie Canal and Trent-Severn Waterway, where much of that has a 10 mph or 10 kph speed limit, you are WAY better off to slow down to your most efficient speed and save a bunch of fuel and get more range.
Run it up to planing speeds, and there is that next "sweet spot", which on our boat seems to be in the 16-18 knot range. But that range is less significant in the ratio compared to slower speeds... perhaps 2.7 miles per gallon vs 2.5. Again, this varies with conditions. So, the performance charts can give you a starting place for estimated fuel burn, but in the "real world" of changing conditions... your mileage may vary. Really. :wink:
Hope that helps.
