ssilver
Member
- Joined
- Sep 11, 2020
- Messages
- 72
- Reaction score
- 0
- C Dory Year
- 2004
- C Dory Model
- 22 Cruiser
- Hull Identification Number
- CD022160j304
- Vessel Name
- Pearly Shell
I swapped out all my fuel lines, vents and filler hose a couple of years ago on my 2004 Cruiser. I got thinking over the summer I should probably do the nearly 20-year-old fuel pickup lines too. Today I pulled the them out and am they are in great shape they are 20” from the strainer to the aluminum fitting in the top of the tank. Must be perfect length I have purposely ran both tanks bone dry in the past. These lines are made of TYGON F-4040-A and have a spring going down them and the ends are nicely crimped. The are not brittle at all. I didn’t realize Moller has replacements but did not see a 20” version? What length are you getting from Moller? Where are you getting them from? Little more to my story one side came out nicely the other side started to move when I had a wrench on the aluminum fitting so I put a pair of vice grips and was able to hold the threads in place and use the box wrench to remove the pickup. To keep that snug and tight I am thinking of a little marine tex around the threaded bung that goes into the tank. Thanks for this post very timely for me!! I must not be the only one thinking spring!!
