Safe to fill from plastic fuel cans?
DaveInRI
Active member
Aug 5, 2024
213
33
Location
Narragansett Bay
2005
CDO22275K405
Once
Is it safe to add fuel using portable plastic containers if on a **floating** dock and/or at sea (/anchor)? Poured, not pumped or siphoned, and let’s say 5 gallons at a time. The concern would be static buildup while pouring and no real bonding. I have read lots of anecdotal accounts where people have been doing it for years without incident, but also quite a few from the small airplane forums where planes and even hangars have burned down, especially during dry colder weather in northern climates when pouring.
For a 22 cruiser with most likely plastic tank, is bounding required or necessary? I don’t think my previous 22 was.
I know you said not siphoned, but I have used the plastic hose with the fitting and glass ball quite a few time to top off my tank at anchor and at home. I find them very easy to use and much less likely to drip any gas anywhere, even if a big wave come along. I’m not sure but I don’t think the hose could buildup static.
Thanks. I have a new “anti-static” siphon like that (copper end with marble type piece inside), but all the new gas cans after 2023 have a screen inside (some plastic, some metal mesh) as a spark arrester for flame jetting prevention, which would have to be pulled out. Once it’s out, it can’t go back in, and then if I explode at the gas station when filling up, the cameras might show it was my fault. Or if I explode while filling up something and it doesn’t fully melt and hide the evidence, it will also show it’s my fault. And I just got to reading “why can’t I just pour from the jug”, and was really surprised at how many small planes burned down from that, and how important it is to stand on the ground when filling. I planned to just buy two 5 gal tanks and remove the plastic and have them as siphon only tanks, but still was hoping to have an actual “answer” about pouring in straight from a plastic can, rather than making my own “probably fine, Mac’s been doing it for 20 years and he hasn’t blown up” decision. All the plane guys seemed to have grounded carts and clip wires to the aircraft and stuff, taking it very seriously, and the boat guys are like “hold my beer while I fill my boat— it’s fine, don’t be a weenie”. Oh, and the VP Racing or Tuff Jug types, and even the expensive Flo Fast jugs (under 10 gal), which don’t have the arrestor or carb compliant spouts, are not rated for on-road transport of fuel by DOT, so you’re not even supposed to use those either. I’ve no interest in a 14 gal Flo n Go style wheelie tank, or a $600 Flo Fast setup. The main science issue is the buildup of static charge in the spout while pouring, especially in colder drier air (like now for me in RI), caused from the movement of fuel through the spout (balloon rubbing on your head effect).
If your deck fill is bonded to ground like it should be, and you keep the plastic spout of the jug in contact with the deck fill as you pour, then it seems no charge can build up? Also, your body might already have a charge so I would discharge yourself to ground while holding the jug before you start pouring. The question then becomes what do you use for ground to discharge yourself? I would hesitate to use the deck fill itself, even if it was closed, so perhaps the outboard motor, which should be grounded.
I did have grounding issues on the survey of my Tomcat, made me concern for my 22 so I check and they was no bonding wire. My guess is it’s common for most 22’s, might be a good idea to add that to yours.
I got a couple gas can with the plastic mesh, I thought this was a filter but since it not really easily removable that seems pretty useless, just learn something new, thanks.
I doubt mine is grounded also. I bought two cheap jugs this morning, removed the white safety screen (needle nose + twist), and used my siphon. Tipping the jug for the last bit got them nearly entirely empty, so I’ll just use that for now. I’d like to know / come to a decision however about pouring right from the jug, though my back thanked me for the “set it on the lazarette and watch” ridiculously easy fill up. Car gas being like $2 less a gallon, jugs were $25 ea (and those were the cheapest they had, nuts), $50 in jugs, 10 gallons gas x $2= $20 saved per dual jug pour, 2.5 fills to pay for the jugs. Siphon was like $13. I forgot gas is less weight per gallon than water, the 5 gallons was very manageable.
That is the best part with the transfer/siphon hose, how easy it is, especially on your back. Pouring directly from a jug, especially the newer one in the US, you need to decide if you’d rather drip gas inside the boat or in the water, neither one are good option. I got one in Canada a couple year ago and they still have the vent, much easier, but I still use the transfer hose.
Amazon sells a number of accessories to convert a modern portable fuel tank into the easier to use "old style" spout and vents.
There is another option you could consider. A battery operated fuel transfer pump. The are equiped with the threaded cap connection that will prevent any spill at the portable gas can and at the other end there is an outomatic shut off so you won't accidently overfill the boat gas can. I think the biggest threat to static build up might be if you drag your gas can across the surface so I would make sure not to do that. They are avaiable on amazon for about $35. I used one when I had bad gas in my tank when I bought the boat. It worked like a champ. Check them out.
On our many extended cruises, I’ve carried up to a mix of ten, 5 & 6-gallon old & newer-style plastic fuel containers with originally no concern for exploding on transfer. When needed, they were picked up and the nozzle inserted in the deck fill, while holding the container. This was hard on the back, so then, I discovered, I could rest the container on the lazarette, while it emptied, which took a while, without the old-style vent. With this transfer done so many times with occasionally minor spillage, I switched to a siphon for a while, but that still required, the container to be lifted and as I became more aware of the possibility of a static caused fire, I found my fill not grounded & fixed that, followed by searching for the small battery-run fuel transfer pump that Schuster mentioned. I found one with a slightly longer hose, that I can now transfer from any of my containers without moving them from their storage position on the boat. I also use the electric fuel transfer pump for fueling the dingy motor & diesel to the Wallas fuel container.
I use this battery-powered pump (which is probably the one Dave is referring to) for fueling motorcycles - easy on the back and no spill. However, I don't think it's any less prone to building up a static charge than using any other plastic jug. Again - make sure the deck fill is grounded and then keep the spout in contact with the deck fill and there shouldn't be any charge buildup.
I’ve been fueling my boat from plastic gas cans, and I just make sure to ground everything by touching the can (closed) and the metal cas cap (also closed) at the same time. It might be unnecessary; I’ve never felt any static or gotten any spark, but it’s an easy precaution.
I bought one of the transfer pumps this summer, and I loved it. Every time I fueled the boat I thought “this is the best gadget *ever!*
And then it died last week. It had lasted all of three months, and hadn’t pumped more than 30 gallons. 😡
So I replaced it with a $10 manual pump with no electrics and precisely *one* moving part, which works perfectly. I fueled the boat today.
One thing worth separating: a battery pump is convenient, but it doesn't remove static risk by itself—the plastic jug, hose and you can all carry charge. Before opening, touch the can to a metal part of the boat/fill to equalize, then keep the spout or nozzle in contact with the deck fill while transferring. Grounding the fill only helps if it's actually bonded to the boat's ground; otherwise you're just touching two isolated metal bits. ChrisD's manual pump is appealing for simplicity, but I'd still treat it the same way.
