Active member
- Joined
- Nov 21, 2004
- Messages
- 5,934
- Reaction score
- 0
- C Dory Year
- 2008
- C Dory Model
- 255 Tomcat
- Vessel Name
- Meant to be
Brent asked for an update here awhile ago and then again on another thread. The bottom line to date is that I replaced the scuppers with a model that are single piece plastic all the way through. I kept the old ones with the idea that I might get around to making new ones out of stainless and I'll use the old ones as a model. The newer plastic ones are better than the older plastic ones in that they don't have a stainless ring on the inside of the transom that can separate from the tube leading to the scupper. The scupper flaps were replaced and that's all I've done. I decided again the sump idea as I really didn't want two more pumps to maintain/replace (there are already 7 pumps on board).
I also had two inspection plates put on the deck (near the aft corners) that make it easier to get to the macerator pumps on the fish boxes and to get to the bilge pumps. I'm thinking I might replace the lids on those with clear lids so I can see into the bilge at all times.
