Well-known member
- Joined
- Oct 2, 2011
- Messages
- 5,086
- Reaction score
- 61
- C Dory Year
- 2009
- C Dory Model
- 25 Cruiser
- Hull Identification Number
- UWH25301J809
- Vessel Name
- C-Traveler
Bringing this one back to life, as I think I need to replace my seals. I know there is a more recent thread:
http://www.c-brats.com/viewtopic.php?t=25817
but this one seems to have a little more information. I have the SeaStar HC5345 steering ram. Every winter I notice just a bit more leakage coming from the starboard ram seal. So far this winter, after putting the boat away in early November, and with a week or two of bitterly cold winter, I have about a tablespoon or two of hydraulic fluid pooled under the starboard ram seal. So think it's time to replace those seals. I've read thru this thread, and the one above, and sounds like it's an easy enough job to do. I'm sure there are some hydraulic shops here in Madison, Wi, that could replace those seals easy enuf, but I pulled some part numbers off on this or the other thread (wiper HW-0750N and Seal DPU 12-0.75-12) and I might see if I can order those on my own first. The question is, will I have some warm enough weather between now and the St. John's gathering in order to do the work, or just wait until after that gathering, and do it before the Friday Harbor gathering. For those of you that have done this job, for the first time, is this pretty quick and easy, or a job that could easily turn into more? And any other advice/suggestions than what's already been posted in these two threads? Thanks. Colby
