Active member
- Joined
- Feb 23, 2012
- Messages
- 3,990
- Reaction score
- 13
- C Dory Year
- 2002
- C Dory Model
- 22 Cruiser
My 22 sits on a tandem trailer that has no side guides. It does have carpeted "half moons" lining the inside of the fenders, but those are hardly guides (maybe more like a ricochet cushions :wink
. While I have highway trailered my boat quite a bit, I have virtually no experience launching/retrieving (this or any other boat). It seems that guides of some sort would be a good idea, but without any experience it's hard to know which ones I'd prefer.
I was wondering if any of you who have used them would care to comment on what you like or don't like about the ones you have - or have tried - and what you would do if you were outfitting a trailer from scratch (no guides).
Here are a few options/styles I have seen, and some "uneducated" thoughts:
1) Heavy duty guide-ons from Pacific Trailer. These certainly look deluxe and up to the task. One thing I'm not sure of is if they would interfere with my normal hopping on and off the boat via the fender (because they only adjust in so far, and go up "straight"). They are also very expensive, at $360 just for the four uprights/mounts, but that's not to say I wouldn't be happy to spend the money if they were "the way to go." On the other hand, I don't want to just buy them because. This photo shows them on SEA3PO, and I have noticed them on C-Hawk (Fishtales) and Jenny B. as well.
2) Lighter duty guide-ons from Pacific Trailer. These are a lot less substantial than the former ones, but if they do the job... great. They angle outward from the attachment point, for whatever that's worth. They are also quite a bit less expensive ($120 for the four uprights).
I think these may be the ones on Blue Rose:
3) Another style of lighter duty ones that I have seen in various places curve around on their way up, and look like these on Nomad. I have also seen them mounted atop the trailer frame vs. beneath.
One concern I have with the lighter duty ones: If you look at this photo of 3rd Byte's trailer with a set of the lighter-type guides, you can see it looks like he added diagonal bracing. That makes me wonder if I might as well spring for the more substantial ones the first time around (I'm not much of a metal worker, and I dislike throwing good money after bad) (of course a certain amount of that seems inevitable in boating, but I might as well at least try to avoid it).
Another factor, which I've mentioned, is that - if possible - I'd like to keep my easy access from ground to boat via the fenders - not sure which or if any particular style has the advantage there. I guess maybe I need to go to a gathering that starts at a launch ramp so I can compare and contrast in real life! But... I'd like to get guides set up before then.
Another question is how high to run them. I've seen some boats on which they run at the level of the sheer stripe, and then others that have them aligned with the first white strake. The Wallas exhaust on my boat is on the first white strake, but then I'm not sure if I'll be reinstalling that, so it may or may not be a concern.
Lastly, these look interesting, but I guess they are more to keep the boat migrating sidways on the trailer while on the road? (They'd be too low to serve as retrieving side guides, right?)
Thanks ahead for any input, both positive, or "if I had it to do over again..."
Sunbeam :hot
Sunbeam :hot
