"Setting up" a trailer for a C-Dory?
My model# is the same as Bob and Tom's. That is the aluminum 5 Starr. And it is 8400# capacity per the sticker on the trailer.
There is a galvanized 5 Starr with a totally different model# and 8000# capacity.
This was in stock and we did find some C Dory 25 pictures on the internet appearing to be using the 4x6 bunks. So we thought that would be ok.
Sorry for all this but if you go to the link I attached earlier my trailer looks exactly like the aluminum 5 Starr with the 2 guide posts, 2 4x6 bunks and the guide front bunks. :smilep
Benton,
I apologize for confusion I may have caused. When I click on your "Link" I get the general page. The 5 star appears to be a galvanized trailer. (which link I gave).
My trailer and Tom's are set up exactly the same.
So you have the aluminum frame, as many of us have, but with the aft bunks on edge (generally used for deep V hulls). Ours are pictured in the link I provided, and are flat on the top 2 x 6 and are supported underneath by galvanized hardware, which will pivot. An essential of this setup is the "target" small bunks forward.
It could be possible to use a planer to arranged the edge contour of your bunks to accommodate the progressive small deadrise of the C Dory 25, to give maximum support. (Removing the cover, contouring the wood, and then recovering.
Lets see what Tom says.
Bob and Tom,
My brain had a disconnect when looking at the model#s. I see your different model is the same except for the 2 long bunks. Mine do not articulate. I am going to get with the dealer and arrange a swap for bunks like yours and then use Tom's numbers to set up.
I don't want to make my bunks work.
For future posts on the subject, would be great to have photos of your actual trailer. I had the same issue going to that link, in that it opened up a general page and wasn't all that clear which trailer you had. I too used Tom's measurements initially, but then tweaked them a bit to work for me. At one point I dropped the bunks down to the lowest holes, allowing to launch a little easier in shallower water, and giving the boat on the trailer just a tiny bit of a lower profile. That also allowed me to move the boat back just a hair on the trailer as the bunks also moved back while being moved down. However, soon after that, I realized that this also allowed the hull to touch the fenders if the boat was not centered well on the trailer, so back to the higher bunk holes. Where I stand now, even if I end up slightly off center, the hull still clears the fenders. I've also moved the aft side posts to just about touch the boat on both sides. This helps center it when I'm solo, however, it also requires me to stop when the boat hits the posts as I'm driving on, as they tend to twist it throwing the bow off center. (Remember, the boat's beam is wider near amidship than it is at the bow or stern. So at that point, it is actually squeezing between the posts.) Turning the motor in the appropriate direction will get the bow lined up before proceeding. Depending upon ramp incline and water level, sometimes I won't back in as far, requiring to power load, and not using the target bunks, (as they are several inches below the hull when boat is sitting hard on the main bunks), or other times using the target bunks to position the boat, and then winching it the rest of the way on as it slides on the target bunks until the bow is high enough thereby causing the hull to rest more squarely on the main bunks. One other caveat in setting up the trailer. And I learned this from the Hull Truth blog. Especially with the aluminum trailers, they tend to bend more at the front of the trailer. So part of setting everything up is getting the boat on the bunks where you want it, and then setting up jack stands on the frame just in front of the axles. Rolling up the tongue jack to take the weight off of it, will allow the aluminum framing to hang free without the weight of the boat baring down on it (as the jack stands are holding the weight of the boat in their location). At this time, adjust the bow stop/mount/winch to fit the boat appropriately. Once you remove the jack stands and lower the tongue jack again, the boat's weight will now be distributed on the main bunks and the front bow stop/roller, and not placing as much stress on the front tongue. Colby
Colby.
I believe that you were suggesting that jack stands go under the boat? not the trailer frame??
I prefer to put concentrated loads on the keel/and then use jack stands to balance the boat. Always try and spread out loads when putting solid points under the boat, even for a short period of time. Ie a 2 x 8 with jacks behind that--maybe a steel plate to distribute the load of a jack to the wood. I have multiple hydraulic jacks and 4 jack stands to use when lifting or moving the boat on the trailer...
Perhaps the way I stated that is misleading.
No; the jack stands go under the frame. Between the ground and the trailer frame.
From a blog on the Hull Truth: " I had read on one of the threads about "Properly" setting up a alum trailer you first placed blocks under the main beams just in front of the axles, then lowered the jack until the weight was off of it. Then adjusted the winch/bow stop to the boat."
Colby
Colby,
Thanks for your input. Sorry my link was so bad.
I went into your albums and saw the pics of your LoadRite when doing the bottom paint. That is what my trailer will look like once I get the AB bunks.
Benton
I got the A,B bunks for my LoadRite trailer making it proper for my 25' C-Dory. Using the info received from you guys I have installed and adjusted the bunks. Now all I need to do is load the boat and double check my handiwork. :thup
