Here are some free comments. and rest assured you'll get a lot more of the same. Please remember that your anchor is a vital piece of safety gear, and not something just to have on board.
First, you're in SoCal, so I assume you'll be boating off the California coast. If you go to any of the islands off Santa Barbara, and you should, you'll be anchoring in some grass and kelp. Journey On's claw anchor (a Bruce,) had trouble digging in kelp/grass. It really refused to set and made us look like we had never anchored before. This was a great anchor everywhere else, but it really has no sharp edges to cut into the kelp. We've had good luck with a Danforth, and I got a Manson, since it has a good point, and it is supposed to hold in every bottom known to mankind. By the way, Bruce anchors ane not available anymore. Fortress anchors are too light to set in kelp. We tried that also.
Second, G-4 chain is hi-test, which with Journey On is equipped. It came with the boat, because that's what fits the anchor windlass.. Since you have a C-22, you may consider G-3 proof coil chain, at half the price. Make sure you get ACCO chain which I hope is still made in the USA. There is 70' of chain on journey On. That may be overdoing it, but get at least 30'. 15' of chain doesn't always do the trick.
If you have a windlass, it's probably sized for 1/2" 3 strand. Even if you don't have a windlass (God's gift to backs and wives,) I'd stick with 1/2" though 3/8" would probably work. The windlass will require a chain to rope splice, which Sea Wolf will explain. they are easy to do and hold well. Get 200' and then you can end-to-end it after a couple of years.
If you don't have a windlass, most anchor lines come with a loop and thimbal in one end. If you want, you can use this loop and shackle it to the anchor, and another shackle to connect the anchor to the other chain end.
To shackle things together, get the biggest shackle whose pin will fit through the chain link, and seize it with stainless wire as Bob mentioned above. I put a swivel between the anchor and rode in place of a shackle.. In addition, you'll find that West Marine usually has imported shackles.
Defender has USA shackles. However, I usually get them from crane rigging services, of which there are several in San Pedro.
Good luck and I hope we meet at Santa Cruz or Catalina Isles. For some SoCal anchorages you'll need an aft anchor also. It can be a lighter anchor.
