Well-known member
- Joined
- Nov 2, 2003
- Messages
- 21,819
- Reaction score
- 176
- C Dory Year
- 2007
- C Dory Model
- 25 Cruiser
- Hull Identification Number
- DOR25652A707
- Vessel Name
- thataway
Diamond Marine in CT. has the 8725 venture trailer for $3895. If you need, brakes on both axles it is an extra $200. I would want a different bunk system than what is shown on that trailer for the C Dory 25, but that may only be a few hundred more--add in tax, and registration--probably going to be in the $4,000 to $5,000 range It is also for a 27 to 29 foot boat, so the balance may be somewhat off for the C Dory 25, but the cheaper, 8025 is sized for a 25 to 26 foot boat--and might be better for the C Dory--with a rated capacity of 8025 lbs. The tires on that trailer are rated at just a listle over 10,000 lbs total (if you go to load range E--you can pick up a bit more capacity...Lots of factors come to play in the trailer rating, beyond the tribe capacity.
If you can get the trailer for $3800, I would have the info ready for the next buyer, and let him buy the trailer--no use paying the tax and registration etc twice--that just cuts into your bottom line. Plus the new owner has the warrantee of a new trailer.
