capt. meares
I posted yesterday how I discovered that a leak was coming down inside my cabin from my anchor nest...
UPDATE...Today I bored out all the holes with a larger drill bit. To my surprise, this took out all the moister/rot, and left dry light colored balsa wood on all the holes except one. The one hole that was the closest to the point of the bow had quite a bit of rot. I removed it all (I hope), with a dental pick, and a sharpened bent nail by hand. I made a second drilled hole to reach farther back and remove more rotted balsa. I estimate the infected area was about the size of a silver dollar, only oval shaped. I then beveled, taped off the bottom and filled all holes with epoxy.
I am fairly confident I got at least 95% of all the rot out, should I lose sleep over any small bit that may have been left behind that is now soaked with resin? If a little moister was left could this come back to be a problem?
