Single Handing Safety Tips and Considerations
No lecture about alcohol on the boat from here. I need a higher level of alertness when on the helm than I do driving down the freeway with all those handy lines to keep you in lane and road signs for guidance ... on the water, more variables, more stuff to keep track of, wet stuff to fall into. A beer or two would compromise me ... but perhaps not you.
And at the end of the day, a tall cold one is a handy relaxer when tied up or on the hook. And I indulge.
What's not to like?
What I refer to as my "All clear beer."
More common sense - about ETOH/boating:
* NEVER underway, just before departing, when pregnant or alone
* If partaking, ALWAYS ashore, on the hook, docked or moored in moderation**,
of course ;-)
* Best enjoyed with friends as a "sundowner" after a great day on the water
Aye.
**Grandpa, an old Navy man who liked fine cigars, pretty women, sharp cheese
and Ezra Brooks bourbon, used to say, "A gentleman never has more than three
martinis before dinner".
I don't drink any beverage containing alcohol while operating the boat or in a vehicle on the highway, but sure do enjoy a ration of Captain Morgan, while on the hook or in the evening at the dock. Concerning needing a clear head more either while operating the boat or the vehicle on the road to me is for the most part comparing apples to apples, but will say on all of our extended cruises to the Southeast Alaska area the nearest we came to disaster on each was while on the road parts of these trips & the worst each happened on the freeways in the greater Seattle area, which I now make sure to transit only in the hours around noon or very late at night.
I'm with you on this Harvey. But too many do mix alcohol with boating (and driving), and unfortunately their idea of moderation is debatable.
Kushtaka" Third (maybe most importantly) get intimately familiar with your boat's response to control inputs. [/quote said:
This paragraph contains a lot of good info. All I can add is, apart from the obvious wind/current,etc. there are a few things that can affect the way your boat turns. LOAD - and how it is distributed. We become familiar fairly quickly how it steers forward but reversing some boaters are less familiar. My boat(single screw I/O) for example is subject to the port walk in reverse because of the drive torque. I discovered on 2 occasions that with it loaded stern heavy for a cruise I could reverse with the helm hard to starboard and it still reversed straight back. Worked myself into a tight corner both times thinking,,, it will come around. Had to use a burst of throttle to get the stern broke loose. A duo prop drive or twin counter rotating engines will negate this effect but my only option was to install a 4 blade prop this summer - reverse thrust, dockside control and manoeuvering in tight channels greatly improved.
Regards, Rob
This discussion does raise an important practical issue: finding the balance between preparedness and overkill with respect to gear. (As I write this I'm sorting out/paring down the contents of 8 tackle boxes full of "necessary" gear which have finally made our fishing experience a cluster***). Same could easily apply to safety gear. To be of value it all needs to be well maintained, its proper use practiced and mastered, stowed where it's easily accessible, and not be so copious that it's in the way, underfoot or the source of further confusion or a false sense of security. Not to be cavalier or a wise-ass, but I think about the sad irony of emergency situation where I go to turn on my handheld VHF, only to find it not working because I haven't charged the battery in many months, because I haven't used it in many months. This pre-supposes I could actually find the damn thing since I haven't laid eyes on it in many months. (I think it's in the under the cuddy storage in the same tote as my flares). My new boating focus is on organizational simplicity: a place for everything and everything in its place. I would welcome photos and suggestions from folks who have overcome the clutter bug on their boat. Cheers, and happy 2015! Mike.
I follow most of the safety tips mentioned above but there are a couple I always do when on my own. I do not leave the cabin without a PFD on, and the boat has to be stopped. As soon as the boat is stopped (if not at the dock) I put out my 'hook on' boarding ladder. I attach a thick piece of rope to the grab bar on the rear cabin bulkhead. This rope has big knots in it every 18" and a loop at the end to put a foot in. This rope hangs next to the ladder for quick access. This procedure is a must before going forward to anchor.
No alcohol consumed until the underway boating is finished for the day. If I am at anchor and I row over to a friends boat for a cold one, I always return to the motherboat before dark.
Martin.
Many good ideas here. I particularly like Westward's on the balance between too much and too little. I also make it a point to have place for everything and put things back after use. To help me, I label the important spots, i.e. A red cross where the first aid kit is, a big label where thef flares are, another for tools, spare anchor,etc. whenever a guest is aboard we go through a location and use checklist so they (theoretically), will know where things are and maybe even how to use the radio and flares. Our inflatable pfds go on before the engines start and come off after we are tied up at the dock. I have a uscgaux supplied Mayday card right by the radio so that guest can make a call after I've fallen overboard. The boat name, description, length,etc. are on labels right by the mike. We enjoy a glass or two of wine/beer but never when underway or within an hour of departure.
The above is the content of our "ditch bag"--and is carried in a fairly small clear "Sea Land" bag. For us this is the "just right" sorted out over many years of boating. This is by the helm, in the dinghy etc. The amount of gear on one's person is fairly simple--and attached to the inflatable PFD or a floatation vest (not the cheap over the head class II often used). The whistle, VHF and PLB.
A swim step with a ladder (and outboard motor near by) allow re-boarding--also any outboard with a tilt/trim will help in re-boarding.
Bob, my Campion had no reboarding ladder. It had a Stingray Foil on the outdrive and it was very easy to step on it and climb onto the swim platform. A marine mechanic told me one time that they didn't serve much purpose on a outdrive. I showed him what I used it for. 8)
One thing I keep in my tool kit as well as the Coleman rain coats is the foil ones that help retain body heat. I inadvertently( :twisted: ) soaked my mother in law one time sitting in the front of my bow rider. I gave her a foil coat and she said it did keep her warm. It also seemed to keep the aliens away! :)
Other good things from Coleman to keep aboard are the red and green light sticks and the hand warmer packs that you shake to activate. They also have camp hangers that come in a 2 pack, 1 red and 1 green. I use them to clamp on my dash fiddles when on the canals. If you do The Trent/Severn both ways you have to change your red/green orientation 3 times. Can be confusing, we watched a houseboat pass on the wrong side of a buoy last Sept. Ran up on a shoal.
Rob
I boat alone most of the time, and I think that any safety regimen begins and ends at the dock. I have seen enough people fall between the dock and their boat that I never take it for granted. For me, my first and last dock line is permanently on the midship cleat, and it is draped through the window where I can reach it from inside and out. On both sides of the boat, I have attached dock lines fore and aft. When leaving the dock, I tie them together when they are free and drop the knot and extra line into the front of the cockpit. The midship line I can remove from the dock cleat while reaching out the window, and drop it behind the seat. When I dock, boat hook always handy, I take the tied lines onto the dock and use them as a bridle to control the boat until the midship line is cleated. After that, for and aft is easy.
On the water, I think that too many hand grips are never enough, including a SS handle on the visor. I don't fish much but that will be the time that the boat bucks around the most, unsteered and slow or drifting. I have a permanently lashed handle (a piece of plastic pipe lashed slackly to the roof rails) that dangles below the cabin roof, and I install a heavy rope on each side between the grab grips and the stern cleats. They slope down, so are no substitute for a proper rail, but they are handy grips.
Fenders present another problem, keeping you near the side and possibly reaching overboard. I carry 4 fenders on my active side, the last being tied to the stern cleat — not too bad. The 3 forward fenders have a line that joins together their bottom loops and terminates at the cockpit where I can tie it to a handle: pull this line snug and cleat it with all 3 fenders clear of the water and up on, or parallel, to the gunwales. To release, uncleat it and give a little yank. It takes a little fiddling to adjust the first time, then it's all good.
For re-entry fom the water (which I never have done,) I keep a portable swim ladder ready to hang on the coaming, and a single step rope ladder rolled up against a stern cleat at all times. In addition, I guess my Doelfin will allow me to climb the outboard or use the engine tilt control for a boost. Jeezh!
Last, but not least, I wear an inflatable PFD, and put it on as soon as I arrive at the boat. Slippery dock, cold water, and the nearest pull down ladder is HOW FAR away?
Happy New Year, and a safe one, to all the Brats.
Rod
If you don"t have a swimstep reboarding using the cavitation plate isn't too difficult if you practice it. Obviously you want to MAKE SURE THE MOTOR IS SHUT OFF AND NO ONE WILL INADVERTENTLY RESTART IT(!)
If you choose to use the cavitation plate as a step, a 4-6" piece of non skid tape applied to the topside of the cavitation plate will help to keep your wet foot in place. If applied to the topside of the cavitation plate it will not adversely affect performance when the boat is on plane. (At displacement speeds it's not a significant factor.)
In addition to the non-skid tape tie a short piece of line (wiith a couple of knots for added grip) to the nearby aft cleat. It'll help as you climb back aboard. If you do this sort of maneuver frequently (e.g. Lake Powell...) consider permanently mounting a SS handhold near the back of the lazarette (where you can reach it while climbing back aboard).
Best,
C&M
Up to this point I have not been using a PLB. I do carry a handheld VHF on my PFD. I am considering adding either a PLB or an individual AIS beacon. Both are about the same price. There is obviously a difference, but it may be that the response time for the PLB could be longer than the AIS response. that would depend on IF there was a vessel with an AIS receiver within range.
Thoughts? It would be great if there was a combined device but thiere is not one that I know of.
SleepyC :moon
1. Solo boating should always be in sober conditions for the captain. Always. Things happen too fast to be fuzzy with alcohol or recreational drugs. Even in night time things can demand you be sober. Be careful, don't get muzzy headed.
2. Always have your equipment and boat in the best possible condition.
3. If in doubt don't go out.
4. Make weather your hobby until you know it in your bones. In new waters be extra careful with weather conditions. Ask fisherfolks for local weather patterns and signs.
5. Trust your intuition.
:female
Hi Anne, Welcome aboard!
(from another former Potter owner)
This thread has turned into a pretty decent resource. Thanks to all for the participation and fine suggestions. I had not given as much personal thought to the alcohol component, probably because it is not part of my life and would not be on board, but, just like the forces of the water we are on, the chemistry of the drug cannot be ignored.
In keeping with my safe boating practices, I recently completed my Vessel Safety Inspection, a voluntary audit of my vessel by a disinterested party, aimed at ensuring compliance and awareness of good safety practices and current dating on safety devices. Everything was in compliance, once I found the Kidde Fire extinguisher defect. It is being replaced by Kidde.
The survey also found that I have some flares that are still current, but do outdate during this season, so they will be replaced soon. (Especially since I just noticed that West Marine has them on sale this weekend for 20 - 25% off.)
The VSI can be done by either Auxillary Coast Guard or Power Squadron folks so it is available in almost any boating community. I would highly recommend making contact and getting the shield sticker applied to a port side window. It could save you some time on the water. On several occasions I have had Coast Guard, or once, a LLE boat come in close, obviously looking for the sticker, see it and wave or thumbs up and off they go. the advantage of the VSI, not tickets are ever written on that one. If something is not right, they tell you what, and give you the chance to make it right (as in my Kidde fire extinguisher moment), and then sing it off when right.
SleepyC :moon
I usually go out by myself an alcohol is not an issue, however last summer I took a couple of friends and they brought a case of beer, which they enjoyed.
The more they enjoyed the more relaxed they became and I realized that I needed to watch them so they didn't do anything stupid, they would be a liability in an emergency (if I needed them them to help or move out of the way) and because some of my attention was devoted to keeping an eye on them I wasn't paying as much attention as I should to what I needed to be doing to skipper the boat safely.
And, if they should fall in, rescuing them, put me and my boat at risk.
This summer, it will be a dry boat (except at anchor or dock) for me AND my passengers.
I just ran across an article in the BoatUS on line magazine that has soe really good tips for those of us that single hand (and even for those that do not). It says it is geared to fishermen, but we all know that there are others that single hand too. Maybe this will trigger some new thoughts and practices for us.
So here it is:
https://www.boatus.com/expert-advice/ex ... aign=eline
https://www.boatus.com/expert-advic...mbership&utm_medium=email&utm_campaign=eline
Enjoy and stay safe.
This is really weird, now the whole post has gone invisible.
SleepyC :moon
