Boris, thanks for the info. Yes, our macerator thru-hull is on the starboard side.
Alan (Simplicity), I sure don't mean to imply that land traveling or camping with the boat is a problem. It IS different from RVing, but it sure beats motels or sleeping on the ground in a tent. :wink: Be sure to get an adapter for your power cord so you can hook up to campground electricity (30 amp, 3-prong, non-twist, or at least a 15 amp grounded adapter). In a campground, we have heat (Wallas or portable elect.), we're able to run any of our appliances, including the TV (many parks have cable). Some campground operators aren't sure what to do with a boat. We tell them "it's set up like a typical RV, 30 amp power, self-contained toilet, etc" and that generally is as far as it goes. We have had NO problem at the majority of campgrounds, but have been turned away from several... not bad considering the miles we've put on trailering the boat. Rather than tell them the size of the boat, we let them know our over-all length (boat/trailer/truck) so they can assign us an appropriate size site. Pick up a Trailer Life Campground Guidebook and you will have ratings of the campgrounds... the middle rating is for cleanliness, generally regarding the shower/bathroom facilities. They also list last year's prices, which are always higher, but it gives you some perspective on the area. When you check in, many of the campgrounds have little check boxes for the type of RV - I just check the travel trailer box and tell 'em "It's just a different shape."
Have fun.
Have fun.
