Sloppy wiring 30 amp shore power
Active member
Sep 30, 2006
4,696
20
2007
25 Cruiser
'Au Kai (Ocean Traveler)
This is the kind of thing that makes my head explode. Simply because it's a simple fix or rather a "don't be sloppy from the start". I replaced the Marinco shore power plug with a Smart Plug. The black wire insulation was slit about 2" up the wire. :amgry I slid marine shrink wrap over it, the kind with glue, so now it won't be an issue. This is on a 2007.
Pics in our album.
Good reminder for all of us to check the shore power connections! Thanks.
Mark,
I would like to think that after you read my post from yesterday on this thread
http://www.c-brats.com/viewtopic.php?t= ... highlight=
...that you immediately drove over to Fisheries Supply and bought and installed a SmartPlug system for your 2007.
Is that the way this went down?
If not, I will be sorely dissapointed.
A good move in any event...most 110v electrical boat fires are at the 70-year old poorly designed boatside shorepower inlet. A great $200 investment, 4 screws, 3 wires, and much easier than changing out a ceiling fan.
I'm almost sure I convinced John Macleod today to get one.
Pics of burned plugs and near-fires that went out when the wire burned through in album (and almost identical pics in Roger's TC255).
Happy Smart Plugging!
I replaced my shore power plug and receptacle with SmartPlugs after a faulty connection took out my battery charger.
Among other things it makes plugging things in so much easier. Should have done it a long time ago.
Search for them on sale. You can save significant $ if you look.
Yes, do the above than buy at WM with price match!
Pics in our album.
You get what you pay for in the labor world, your lucky they were in the correct holes. I had a 1991 22 cruiser, the 12v wiring was very professional/clean install. The 2003 25 I now have was a wiring MESS when I purchased it. Same kid probably wired your 110V.
:mrgreen:
