Small purchases that make a difference
Joe
What a nice looking boat. This is the first time I have seen a picture of the Sea Wolf.
Little John with Lady Jane adaptor for discrete urination in the cabin or cockpit, depending on privacy/surroundings. Does away with the need for Marcia to drag out the porta potty. Available ffrom Cabela's. (photo on last page of our album)
Nick
"Valkyrie"
Here's an inexpensive addition from another thread:
Window tinting!
(Cheap at least if you do it yourself)
Provides privacy and seclusion in the cabin.
The good news is you only have to do the side windows and rear door window. The front windows are left clear for maximum night vision.
Probably costs $25-40 for DIY, quite a bit more for someone to do it for you.
Joe. :teeth :thup
We use a 400 watt inverter (30 to 40 dollars) along with a six outlet type surge suppresor for powering our wireless modem, laptops, camera battery chargers and cell phone chargers. We have a cigarette lighter outlet on the front of the rear dinette seat for the inverter to plug into. This allows for all this stuff to be up and running while we are cruising. This way we run coastal explorer software on the laptop while putting our boat on course with the hand held auto pilot. Plus at night I can run a cpap machine off the same power strip inverter combo. We can have our anchor light on and have all this running on the house battery and still not have to switch to the second battery to start the motor in the am. We use the same inverter and power strip setup in the truck for internet access using a USB type cell card in conjunction with a wireless modem to get info we need while speeding down the highway.
D.D
BrentB":hinran6b said:
Canning wax can be used too
ex Gulfwax Household Paraffin Wax
We used a candle (unlit of course) on zipers and snaps
$20 George Foreman grill. Works beautifully with my 1500 watt inverter that also powers up the microwave. No more gas grills to haul around.
-Greg
D.D
Will
I've been looking for a good 400 watt Inverter. Love to know what kind you are using and if your pleased with it?
H :wink:
6ft. of plastic sprial wrap from an electronics store.
Put it around the fuel lines and control cables to keep
them from marking up the insde of the motor well. :thup
Jack... :smiled
Wiper delay switches for port and starboard. Cuz it hardly ever rains hard here.
Eva-Dry Edv-2200 Mid-Size Dehumidifier. We've had our Tomcat for nearly two years and it still smells brand new. We don't allow anyone to walk in while wearing wet scuba gear. It's been foggy a lot lately, so we're adding a second dehumidifier this afternoon. I've been aboard too many boats with that familiar musty smell. I prefer fresh air. :)
I love my cozy bunk, but after a few months of being aboard every night I started to have things like hip joints and back places be cranky on awakening so I got a memory foam topper at camp walmart and man what a difference. I got the inch and a half one and just laid it in there and in a couple days no more cranky joints. About $60.
1) A switch for the port wiper, located in front of the passenger, so they can turn it on and off themselves.
2) Engine trim switches on the helm, so that the engines can be trimmed easily, without accidentally knocking the throttle up or down.
3) A stainless steel, female eye-bolt, threaded on the inside thread of the bow u-bolt, so the bitter-end of the rope can be tied off inside the locker.
4) Those awesome lazarette covers that Joel found, so I don't get splashed every time I close the aft lockers. They also keep them dry inside.
David
Most Awesome, - Least expensive --> A $4.99 plastic turkey baster from Walmart. With a rubber tip. Much faster at drying the bilge box (under the door step) than a sponge.
A $2.79 foam pipe insulation section. Slides over the VHF antenna when it is laying down on the cabin top. ( It extends back into the cockpit space. The foam is easy to see, and saves eyes.)
A small rectangular convex mirror, mounted on the shelf, so I can easily see anyone in the cockpit when we are running.
A small, 2 position switch mounted between the 2 VHF's. It flips toward whichever one is active for fog or PA service.
David
David this is a GREAT idea, where did you find this? Do you remember the size of the thread by chance??
Peter
I pulled out all the rope and chain from our locker last night so I could check the length (only 6' chain...), but the bitter end of the rope was attached to a piece of wood big enough to not go through the deck pipe.
MY Max Burton 1800-Watt Induction Cooktop. Was $65 so a little over the $50. Amazing you can put a piece of paper between the burner and the pot and it will not burn. In fact you can put an ice cube on half the burner and it will not melt while you cook on the other half. Feels a lot safer on a boat. Boils a quart of water in less than 3 minutes. I run it off my 1500 inverter, or Yamaha 2000 generator, or shore power. Also generates no heat into the cabin except from the cooking food itself and the pan heat.
Ron
Peter_BDA":j7nhlsgz said:
David
Peter
Today I did some work in the anchor locker and took a look in there. Surprisingly, my boat has an eye bolt too, but for some reason my bitter end was attached to a loose piece of wood as I had mentioned before. I wonder why the owner changed it?
