colbysmith":2bikzsrc said:Over the past month or so, after purchasing C-Traveler, I've been doing a lot of installations and changes. The latest was getting the autopilot installation finished up, and installing an am/fm radio. Still have projects I want to do, but finally also spending a little bit of time on the lakes as well. Have taken a few pictures of changes I'm making, and those can be found in the C-Traveler nested photo album: http://www.c-brats.com/modules.php?...ame=gallery&file=index&include=view_album.php Colby
I see you removed the KISS stove and replaced it with butcher block. That is a great idea. I need to do the same thing (my stove is already out). Where did you get the butcher block and how did you attach it to the counter top?
I also installed a new Simrad RS35 VHF radio that connects to the NMEA2000 network that "should" allow me to make DCS direct calls directly to vessels activated from the chartplotter. Does anyone know if it actually as seamless as Simrad boasts it to be? It also has something called "buddy tracking" that looks interesting, and I assume it keeps track of a buddy's position on the plotter.
colbysmith":1owm9b87 said:I also installed a new Simrad RS35 VHF radio that connects to the NMEA2000 network that "should" allow me to make DCS direct calls directly to vessels activated from the chartplotter. Does anyone know if it actually as seamless as Simrad boasts it to be? It also has something called "buddy tracking" that looks interesting, and I assume it keeps track of a buddy's position on the plotter.
Seamless? All depends. I have done DSC calls and the problem tends to be the callee not knowing how to answer. If both you and the person you are calling know your individual radio's operation for making the calls, it works slick. In the long run, it's probably easier to just pick the microphone up and call whoever you are looking for the regular way. However, if the channel is busy or you want to call someone without alerting anyone else on 9 or 16, or go to a discreet channel, then it's a nice feature. I have not used the position reporting, but that can be set up to work as well, as long as both know how to setup the operation. Colby
