Pacificcoast101
Active member
- Joined
- Sep 28, 2007
- Messages
- 770
- Reaction score
- 33
- Location
- Torrance
- C Dory Year
- 2008
- C Dory Model
- 255 Tomcat
- Vessel Name
- No Pressure
gulfcoast john":374m88gl said:We were on a long bridge on the FL turnpike, and the tire monitor system alarm went off within 10-15 seconds for falling pressure (normal temp) in that tire. By the time we got off the turnpike on the shoulder and stopped, pressure had fallen to 8 PSI. At least it wasn’t an explosive blowout, as all of our four non-Goodyear Endurance trailer tires explosions were prior to switching.
garyf I didn't know TMS on a trailer was a thing... tell me more. Is that something you added? Seems like a good idea. Glad things worked out OK.[/quote said:Many of us have tire pressure and temperature monitors on our trailer tires. I have been using this for many years. Same monitors as you use on the truck, if it an older one which does not have internal sensors.
The sensor screws on the valve stem instead of a cap. Some are flow thru, others are just the sensor, which has to be removed if you need to add air.
For some monitors you have to have metal stems. There are also internal tire monitors, but I consider the external accurate enough.
Even with the sensors, I do a walk around the trailer every 2 hours, and either feel the hubs or use an IR thermometer to check for hub temperature. The ones on the sunny side will slow a slightly higher temperature,
thataway":zi4uvzxh said:Many of us have tire pressure and temperature monitors on our trailer tires. I have been using this for many years. Same monitors as you use on the truck, if it an older one which does not have internal sensors.
I'll never forget Rumpole. (Remember him in the Beatle's movies?)She Who Must Be Obeyed
