I debated to put this on here and figured the moderators can kill this thread if need be. I looked around the forum and found plenty of advise on panel sizes...but installs seemed to be few and far between.
I'm looking at installing a temporary solar charging system for the batteries on my boat that is 90% of the time under a cover. So basically when the boat is on the trailer it's charging - but the system is not connected when off the trailer. Coming clean here - this is a Glacier Bay 2670. It stays on trailer but under a cover in Tampa, FL. So crazy T storms and humidity is an every day event in the summer.
I pretty much get the concept of the panels, a controller, and wiring, but I'm struggling with the concept of water getting on the controller through condensation/humidity/rain. I think I have a couple dry spots to connect, but I have this vision of water tricking down the wire shorting something out and causing a fire.
With that in mind the best way to describe it is that the batteries are in the stern and are in individual compartments - so nothing is exposed to the elements.
I can picture putting a controller inside that compartment, but can it handle that humidity? So the wires that connect the panel to the controller would be under a gunnel (outside, under a gunnel but under a boat cover) and I would have to drill a hole for the panels wire to reach the controller inside the compartment. When not charging the panel comes off and stowed somewhere - truck/boat...
Hopefully that makes sense - basically I'm looking to see/hear how to mitigate fires/shorts. I'm sure I'm not the first encounter this, but apparently me google skills are failing me.
I don't think it makes any difference but the batteries are Optima Marine D31's. They are in separate compartments about 6' apart.
