- Joined
- Nov 2, 2003
- Messages
- 8,561
- Reaction score
- 1
- C Dory Year
- 2005
- C Dory Model
- 25 Cruiser
- Vessel Name
- Daydream
It seems that every CD25 with a BF130 / 150 experiences the same problem on Lake Powell - terrible performance, the CD25 becomes a 7 knot trawler (not necessarily a bad thing on Lake Powell!). If you put the hammer down, you might get up to 12 or 14 knots burning 12 or 14 gallons per hour! The BF40 / 50 / 90s seem to be little affected or not affected at all. So it makes it real hard for the CD25s to run with the CD22s.
I propped down to my original Honda prop, a SS 14.5 x 15, which spins up way too many RPMs and goes nowhere at sea level, which worked way better than my regular sea level prop, a Quicksilver 15.5 x 15, which is a wonderful performer at sea level. Still way too much pitch for Lake Powell I guess.
This year, Ken on Woodduck apparently solved the Lake Powell dilemma - with a 15 x 13.5 prop. He reported being able to achieve 20 knots with normal fuel consumption. I looked online and I can get an aluminum prop, either 14 x 13 or 16 x 13, for about $140 - $160, I am thinking the 16 x 13 might be the one...thoughts?
Another potential solution per Russ on Traveler might be that certain BF150s (serial number dependent) might benefit from a different ECM (electonic control module) - Traveler was really affected, so he checked by phone with his certified Honda tech back in Chinook, WA, and found out there was a bulletin on this from Honda. So I will check into this as well.
If anybody has any other thoughts on how to maximize high altitude performance on the BF 130 / 150s, I am sure several of us would be anxious to here them!
