matt_unique
Today I continued some spring prep work. I replaced my Racor filters and after Dr. Bob's recent post drained my fuel water separators in each of the engine cowls. I added some gas to each tank as well.
I have never been able to get a stream when connected to muffs so I always dunk the engines in a large tub of water. Both engines fired right up but no stream of water. I only let them run for 5-10 seconds then shut them down. I then decided to run some water through the forward flush port without the engine running the make sure water could flow through the cooling tube fine. There was no evidence of debris. I removed the hose and fired up the engines. The engines immediately began "peeing" on their own. I ran each engine for a good 15 minutes verifying the charge and all that.
Is that an S.O.P. I was unaware of after being dry for the winter? It seems odd I would have the same problem on two engines if no. Over the next couple of days I will test them again to make sure they pee based on a draw from the tub.
Second question, what is the manual referring to for a grease point titled "steering bracket"? I can't for the life of me match up the picture they show with anything that looks like it needs grease. The rest of the grease points are identified easily.
