flatfishfool
- Joined
- Apr 11, 2009
- Messages
- 60
- Reaction score
- 1
- C Dory Year
- 2002
- C Dory Model
- 24 Tomcat
Hi all, I have a new to me 22CD cruiser with twin 2001 40HP Honda's, carbureted obviously, just under 1300 hours. They have had timing belts done and one had a new lower unit (date unknown).
I recently took it for its first shakedown cruise at a large lake and have an issue with the port side motor where it makes a fairly loud squealing sound when running in the 2000-2500RPM range. Outside that range I do not hear anything and in the hour or so we ran it that day it otherwise seemed totally fine. Squeal sounds like you'd expect a belt to sound like, like when a car water pump or power steering pump is going out. I pulled the cowling off underway and it sounded like it was coming from the engine vs lower unit, though it's very hard to tell.
I have done a bunch of searching on C-Brats and elsewhere to try to diagnose. The only clear lead I have is reference to Yamaha and Merc outboards of similar vintage (and newer) where they make a belt squealing sound at various RPMs, but typically just in a range of RPMs. Diagnosis is a little fuzzy but has something to do with the drive shaft and either the seal at the top of the lower unit or the shaft itself needing lubrication. But I have not found anything about this and Hondas. I will probably try the fix since I am waiting for professional help.
I also found a reference to a high pitched "tinny" whine akin to rubbing your finger around a crystal wine glass and some sort of Honda aluminum prop harmonics, but I think the sound I am hearing does not match that description so I am skeptical that's my problem.
I pulled the cover and plastic off the top and the timing belt looks totally fine, no deterioration or dust all over etc, and tensioner pulley looks very clean and like it was replaced with the timing belt as you'd expect, though I can't be 100% sure. I didn't take any of that apart since it starts to get deeper there.
I am in line at several outboard shops but since that is a long and perilous path this time of year and I am reluctant to use it until I resolve, I thought I would ask the brain trust if anyone has ideas. And yes I have been following the twins repower thread with a very specific curiousity.
