Stainless Motorwell protective bar
Mike_J,
Maybe this image will help. This is where our transom bar was before I removed and installed a cooler rack.
I also agree with Marc on the use of those bimini ss parts. They give you flexibility with adapting to angles. I also used those for our dinghy bracket, also since removed. :D
Peter, where do you keep your downrigger balls? I have my downrigger's mounted as yours, but have not yet figured out where to keep the balls.
Mile, I actually keep the DR balls on the shelf under the gunnels. I have those plastic dr ball holders sitting on the shelf. It is not screwed down as I remove the Dr balls when we're on cruising only trips.
Many people screw down the holders directly behind the lazarettes. Hope this helps.
Peter
Thanks. I had seen the Scotty ball holders mounted behind the lazarette and was trying to decide if they would be in the way..
Stainless steel schedule 40 from a pipe wholesaler, stainless steel plating, and a local welder would the the cheaper than "West Marine". At least around my area.
Or you could get the Scotty hooks for your downrigger and keep them ready for use at any time. During the winter when not fishing I keep them in the ball holder in the cabin storage.
As Marc mentioned, our SS bars in the well of the 25 were made from 1" SS tubing and standard Bimini fittings. Not expensive.
I finally got my transom bar done and have posted some pics in my album: http://www.c-brats.com/modules.php?set_ ... _album.php
I have forgotten how to insert images from an album...
I ended up buying some 1 inch SS bar and some bimini ends from west marine - total cost including bolts etc was under $150 CDN.
Worked well for fishing last Sunday, and I am planning on making a second bar further forward so that I can make a platform if I need it. The current location was great for fishing.
I like the fact that the whole thing is easy to remove.
I put a washer in the bimini joint to make it less wiggly. This photo shows the details:
http://www.c-brats.com/modules.php?set_ ... _photo.php
I also mounted some downrigger ball holders near the stern - again worked out well for salmon fishing this past weekend. Photo at: http://www.c-brats.com/modules.php?set_ ... _photo.php
example of S/S bimini connections on a cd-22
1999_22_C_Dory_Cruiser_002
