i do, its just im spending all my time working on the boat and when i get home im too tired to upload pics, i will tonight or tomorrow though, i can tell you the back stand is made so that there are two pads aprox. 5x7" spaced so that they are centered between the two outer most stringers and the one just inboard of them, so you can access all of the stringers, the front one is made so that it contacts the hull on each side of the center stringer, but not the stringer, its like two smaller pads that straddle it, the two stands are independent of each each other so you can place them under the boat anywhere for or aft that you like, i prepped and painted the bottom, then waited a few days, and move the stands and pained the three small areas that were covered by the pads, they are very stable to, i was able to work in the boat and walk all over it and it didn't move at all, you could probably put 4 22'ers on them and they'd stay put, i used a cart with 4 inch casters to roll around under the boat, so it cleared the bottom of the racks, making access very easy, all this will be clear with pictures, coming soon...
