Foggy":2n60tt0h said:
Why not try cleaning them up with an old tooth brush, toothpaste. If you can get the pins out and clean them too, I'd rub on some paraffin wax, reassemble and get on my way.
I have a brand new set of pins I sourced from the manufacturer, so if I remove the old ones, I think I'll go with the new ones upon reassembly. For now, the window not opening (easily) is not really hindering me because I'm in a cool area, but I do want to get it taken care of before heading to warmer climes, and, well, I just like things to all be operational, so I figured I'd check in here, since so many of you have the same window.
Applying oil products to hinges seems to attract dirt and grime, per your photos.
It certainly does :wink: I probably should have used Teflon in the first place. I don't have much of an excuse (since I really know better) except for being in the middle of about forty other projects at the time and just not thinking straight. I guess the saving grace is that the dirt comes off, and the hinges, while not improving any, also did not get any worse. If/when I lube these (or the new ones) going forward, I'll use the Teflon spray as recommended by Diamond Sea Glaze. I even already have some with me, and so could have used it in the beginning if only I'd thought of it :crook (in fact, maybe I'll try it on the current hinge pins before removing them.
I'll keep the thread updated when there is anything to report, and of course I'm always happy to read the thoughts of fellow Brats. Thanks all.
PS: I looked up a roll punch - that looks like it would work really well, and better than a dowel because of having a tapered end. Just for the record, this is now the approximately 307th time I've regretted leaving my set of centering punches at home. I even
had them in the van, but then decided I was just taking too much along and put them back in the shop :cry
